engine missfires. EGR valve? fuel pump?
BIGJ2007
  • 8 POSTS
1999 honda accord 4 cyl vtec 130000
i had error codes read, said the engine is missfireing, i changed the plugs and wires. next thing i was told to check was the egr valve, and the fuel filter. found out there is no fuel filter to change, but there is a pump. and then was told i shouldnt do this myself. is it that bad? the car runs but it shakes bad. please any help out there????????????????
Aug 21, 2007 at 2:22 PM
  • 75,988 POSTS
[quote:6b6fad40f2="BigJ2007"]1999 honda accord 4 cyl vtec 130000
i had error codes read, said the engine is missfireing, i changed the plugs and wires. next thing i was told to check was the egr valve, and the fuel filter. found out there is no fuel filter to change, but there is a pump. and then was told i shouldnt do this myself. is it that bad? the car runs but it shakes bad. please any help out there????????????????[/quote:6b6fad40f2]
What code/s are they ?
Aug 21, 2007 at 3:07 PM
BIGJ2007
  • 8 POSTS
they are p0302, p0304, p0401, p0300, p1399, p0401. I cleared all of them ran it again for 5 min and scanned it again now it has P0302, P1399.
What should I do?
Aug 23, 2007 at 9:53 AM
  • 75,988 POSTS
1399 is your engine diesel?
Open up the EGR inspect/clean/test-rescan it and comeback
Aug 23, 2007 at 10:14 AM
BIGJ2007
  • 8 POSTS
It is not a diesel, it i s a 4 cyl vtec. I am going to try right now. What should i be looking for? buildup?
Aug 23, 2007 at 11:09 AM
  • 75,988 POSTS
Carbon build up check the passages also make sure its getting vacuum
Aug 23, 2007 at 11:13 AM
BIGJ2007
  • 8 POSTS
i cleaned it out there was a lot of carbon, didnt help any, rescanned, p0300, p0301, p0304, p1399. where should i look to check the vacuum?
Aug 23, 2007 at 11:39 AM
  • 75,988 POSTS
Misfires can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Aug 23, 2007 at 10:02 PM
BIGJ2007
  • 8 POSTS
Well i changed the egr valve, no dice. ill check the compression and fuel pressure. if its the compression, what would be my next step?
Aug 24, 2007 at 3:19 PM
  • 75,988 POSTS
I would say concentrate on the fuel in your situation
Aug 24, 2007 at 3:26 PM
BIGJ2007
  • 8 POSTS
its a "dead cylinder". im gonna sell the car for $1000 as-is. then im gonna go buy a dodge charger. thank you so much for your help!!!!!!!!!!!
Aug 27, 2007 at 12:38 PM
  • 75,988 POSTS
You're Welcome!
Aug 27, 2007 at 4:52 PM
