1998 Honda Accord DRL Light Out
HARVEY_N
1998 HONDA ACCORD EX-V6 216000KM ONTARIO CANADA. In driving status the DRL indicator light is "ON' and no daytine running light, another lights is ok. What problem is with my car?
May 28, 2006 at 12:56 PM
BRIGHTSTAR
Repair Your Honda Accord DRL Module and Save $200
Daytime Running Lights not working anymore? Is your DRL light on intermittantly? Have you gotten the rude suprise that your DRL module has gone tattletale on you, being presented with a $200+ repair bill even though your lights still work? Wonder why that box costs so much? Do you know that there is an easy fix, but can't find out where the hell that relay is, or what it looks like, because all of the manuals cater to the american version of the car, and the crummy line drawing isn't cutting it?
This site is for you! In under an hour, you can repair your DRL module in most cases. The defect is solder joints that go bad over time. It is trivial to repair.
You'll need to find:
A soldering iron
Flux core solder (Kester 44 is fine)
Flathead screwdriver or other prying implement
Some patience
Step one is locating the DRL module and removing it. The relay is located above the gas pedal in a 1996 (5th generation) Accord. It's way, way up there. You will have an easier time if you remove the dash panel from the drivers side first; It pulls out with clips. Start on the corner and work your way over.
Look for the plastic grey box pictured below, with the characteristic BLUE connector. You remove it by pushing UP until it slides off the connector. It is easier if you remove the connector before you pull it off, but it doesn't matter either way.
Oct 4, 2006 at 10:56 AM
BRUCE HUNT
  • 3,754 POSTS
Great job Brightstar. I hope that was helpful to harvey. Stay with us and help out on the site.
Oct 5, 2006 at 12:22 AM
Suggested Repair
Locate the DRL control module, remove it, and resolder the cracked solder joints that commonly fail. A soldering iron, flux-core solder, and a flat tool to release the dash clips are typically needed.
Conversation Summary
A 1998 Honda Accord owner reported the DRL indicator staying on while the daytime running lights did not work, with other lights operating normally. A detailed reply said the usual cause is failed solder joints in the DRL module and described removing the module and resoldering those joints. An expert thanked the contributor and indicated the information should help the owner.
