1992 Honda Accord Brake light
RDYKONIG
  • 1992 HONDA ACCORD
Brakes problem
1992 Honda Accord 4 cyl Front Wheel Drive Automatic 218000 kilometers
When I stepped on the brake pedal to check the rear exterior brake lights, the driver's side lits but the passenger side and high mount or third brake light do not. What seems to be the problem?
Thanks!
Thursday, October 8th, 2009 AT 10:56 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Have you replaced the bulbs?
Friday, October 9th, 2009 AT 2:05 PM
RDYKONIG
I have changed the bulbs, still does not work. Definitely not the bulbs.
Friday, October 9th, 2009 AT 2:23 PM
BLUELIGHTNIN6
  • 16,542 POSTS
If the bulbs are good and only 1 lamp works properly then there must be a fault in wiring. You will need to inspect the wiring at the brake lamp switch as well as at the bulb housings.
Friday, October 9th, 2009 AT 2:39 PM
