1996 Honda Accord Clearance Light Fix
MEGOLODON
How do I replace the front right clearance light on a 1996 Honda Accord 2.2L 5-speed,(150000 K)?
Oct 25, 2007 at 8:23 AM
BRUCE HUNT
  • 3,754 POSTS
Usually under the hood there is a screw that holds a plastic arm in place connected to the fixture. Remove it and the unit should slide out. There are generally little plastic legs in the back end the go into holes to secure the rear of the fixture. Be careful not to break them.
Oct 25, 2007 at 9:53 AM
Suggested Repair
Under the hood, remove the screw holding the plastic arm to the clearance-light fixture, then slide the unit out. Watch the small plastic legs at the rear that fit into holes so they do not break.
Conversation Summary
The owner asked how to replace the front right clearance light on a 1996 Honda Accord 2.2L 5-speed with about 150,000 km. The expert said a screw under the hood usually holds a plastic arm to the fixture; removing it lets the unit slide out, and rear plastic legs that seat in holes should be handled carefully.
