2002 Honda Accord Dash Lights Dim
HAGIOS7
I have an 02 Honda Accord SE, 4 cyl v-tec with 75000 miles on it. Just noticed this morning that when I turn on my headlights the dash lights get very dim. Have had no problems starting the car, she cranks right up, but the "maintenance required" light has come on as well. Is this a problem with the switch or something more serious? Thanks.
Mar 23, 2007 at 1:51 AM
BRUCE HUNT
  • 3,754 POSTS
Has someone turned the dimmer control for the lights? The maintenance required light is something that you can reset. It is kind of like an alarm clock. Resetting instructions are in the owners manual.
Mar 26, 2007 at 2:58 AM
HAGIOS7
There is no dimmer control, it adjusts automatically. The problem only occurs when I turn on the headlights. I just found out that it may be my battery, water may be low, or cell is starting to die.
Mar 27, 2007 at 1:46 AM
  • 75,988 POSTS
[quote:0da5925535="hagios7"]There is no dimmer control, it adjusts automatically. The problem only occurs when I turn on the headlights. I just found out that it may be my battery, water may be low, or cell is starting to die.[/quote:0da5925535]
Check your charging system
Mar 27, 2007 at 2:17 PM
Suggested Repair
Check the charging system, including battery condition and charging output. The maintenance required light is a resettable reminder; follow the owner's manual reset procedure.
Conversation Summary
The owner of a 2002 Honda Accord reported that the dash lights become very dim when the headlights are turned on, and the maintenance required light is also on. Starting is normal. One expert asked about the dash dimmer and said the maintenance light can be reset using the owner's manual. The owner said the dimmer adjusts automatically and suspected a weak battery. Another expert advised checking the charging system.
