2000 Honda Accord Warm Restart Stalls
THOMAS79
I have a 2000 honda accord EX V6 automatic with about 80k miles on it and every morning when I start it to go to work, it runs fine. Same when driving home from work(about 30 to 40 min drive), but after going home from work and let the car rest for about 10+ min, I start the car again, the rpm will go up and down continuously and some times shut off after a few seconds. If I give it some gas and put it on D quickly, it would run without any problem. Can someone tell me what's wrong with it. Thanks.
Jan 29, 2007 at 3:27 PM
BRUCE HUNT
  • 3,754 POSTS
Please take this to heart. Check the coolant level of the car. Make sure it is topped off AND has no air in the system. There is a bleeder on the top hose I believe near the engine. Top the coolant, get the engine warm, and slowly open the bleeder and let out vapor, steam, air. Close and try again several times to get the air out. This should dismiss the problem you have been having.
Jan 30, 2007 at 3:20 AM
THOMAS79
Hi Bruce, thanks for the advice, I will try it out sometimes today or tomorrow.
Jan 30, 2007 at 3:29 AM
Suggested Repair
Check and top off the coolant, then bleed air from the cooling system. With the engine warm, slowly open the bleeder on the top hose near the engine to release vapor, steam, and air, then close it and repeat until the air is gone.
Conversation Summary
A 2000 Honda Accord EX V6 starts and runs normally when cold and after a longer drive, but after resting about 10 minutes while warm the RPM fluctuates and it may stall within seconds. Giving it gas and shifting into Drive quickly keeps it running. The expert advised topping off the coolant and bleeding trapped air from the system, which should resolve the problem. The owner said they would try that advice.
