1995 Honda Accord Shakes When Accelerating
AVAANTI
Honda Accord, EX, 95, 183k, 2.4. My car shakes/vibrates a little when accelerating. After attaining the speed, the drive is quite smooth. Need help in diagnosing the problem. I recently had both axels and spark plugs changed.
May 8, 2007 at 5:44 AM
BRUCE HUNT
  • 3,754 POSTS
Prior to the axles being replaced did the car have this problem? I am suspecting that the wheels are out of balance, particularly the front and even then it might be just one. It could be that a wheel weight was knocked off during repair or on the road.
May 8, 2007 at 6:57 AM
AVAANTI
no, it didnt not have this problem before the change. As a matter of fact, it didnt have this shaking for a week or so after the work was done. I started noticing while coming back from a long distance trip. But, I do not recall my car hitting anything on the trip.
May 8, 2007 at 7:52 AM
BRUCE HUNT
  • 3,754 POSTS
I still recommend looking at the tire balance and a possibility of a tire cord problem. You don't really need to have hit anything for these problems to surface. For instance, if a wheel weight is nugged and loosened, the certifical force of the wheel as it spins can finish the removal of the weight.
May 9, 2007 at 2:35 AM
AVAANTI
I'll get it checked for balance. Thanks for your advice
May 9, 2007 at 9:11 AM
Suggested Repair
Have the tires balanced, especially the front wheels, and inspect for a missing wheel weight or a tire cord problem.
Conversation Summary
A 1995 Honda Accord began vibrating slightly during acceleration about a week after both axles and the spark plugs were replaced; it drives smoothly once speed is reached. The owner said the shaking was not present before the repair and did not recall hitting anything. The expert recommended checking tire balance, particularly the front wheels, and considering a missing wheel weight or tire cord problem. The owner planned to have the balance checked.
