1988 Honda Accord Shakes at Stop
RIQUEENALWAYS
this is for a 1988 Honda Accord LXI mileage is 186,000 When I come to a complete stop the car shakes like crazy can u tell me why... I have been told that it may be an idle problem.... just not sure please help
Mar 5, 2007 at 10:26 AM
BRUCE HUNT
  • 3,754 POSTS
I would try to determine if the engine is the problem or maybe you have a broken motor mount. If it is the engine, I would start by checking the spark to each cylinder. I could be as simple as a bad wire or a broken spark plug.
Mar 6, 2007 at 5:29 AM
COLOBLEU
trans mounts valve alignment vacuum leaks ( base of carb, intake manifold) main relay, etc
Nov 23, 2022 at 4:29 AM
Suggested Repair
Determine whether the shaking is from a broken motor mount or an engine problem. If it is the engine, check spark at each cylinder, including plug wires and spark plugs. Also consider transmission mounts and vacuum leaks if those checks are inconclusive.
Conversation Summary
The owner of a 1988 Honda Accord LXI with 186,000 miles reports severe shaking when coming to a complete stop and wonders whether it is an idle problem. An expert suggests checking for a broken motor mount and, if the engine is at fault, inspecting spark, wires, and plugs. Another reply lists transmission mounts, valve alignment, vacuum leaks, and the main relay as possible causes.
