1992 Honda Accord Clutch Pedal to Floor
VISIONZTECHNOLOGY
1992 HONDA ACCORD 2.2 LX 500K , AFTER FILLING WITH BRAKE FLUID , TRIED TO DEPREES CLUTCH , WENT TO THE FLOOR. IT WOULD NOT ENGAGE. THE FLUID NEVER WENT DOWN EITHER FOR BLEEDING. DO YOU KNOW WHAT I AM DOING WRONG?
Jul 30, 2007 at 8:18 AM
BRUCE HUNT
  • 3,754 POSTS
Either the seals are that bad in the master or you have a possible opening that is not allowing the system to accept pressure. Is the bleeder open? You may have to pull the pedal off the floor. Pump it several times to see if it has any resistance.
Jul 30, 2007 at 8:50 AM
Suggested Repair
Confirm the bleeder is open, pull the clutch pedal up off the floor, and pump it several times to see if resistance returns. If the system still will not build pressure or take fluid, the master cylinder seals may be bad or an opening may be preventing the system from accepting pressure.
Conversation Summary
The owner of a 1992 Honda Accord filled the clutch with brake fluid, after which the pedal went to the floor and would not engage. The fluid level also did not drop during bleeding. The expert says the master cylinder seals may be bad or an opening may be preventing pressure, and advises checking that the bleeder is open, lifting the pedal off the floor, and pumping it to check for resistance.
