Hello All
The clutch in my Accord is very stiff to depress. It shifts into forward gears ok without grinding, but the reverse gear will grind if I dont fully depress the clutch pedal.
The fluid level in the master cylinder was completely low, and the rubber gasket was sucked in. I did add fluid, and the clutch does seem "slightly" easier.
I am bringing it in to the mechanic today to have them test drive it.
My question are
1. does it sound like the clutch needs to be rebuilt (the searches I looked at on the board point to it :roll: )
2. how much will this cost. The garage is a local one and they charge $49 an hour.
3. Should they use geniune honda parts, or can they use auto store parts.
4. Could just bleeding the clutch and replacing the new fluid help for now?
5. is this something that needs to be fixed NOW! - will it cause serious damage if I drive it?
6. What other things should I have them look for, or I should be aware of as the customer.
Thanks
Leggo
My question are
Thanks
Leggo
May 4, 2006 at 7:22 AM
