1997 Honda Accord Dim Lights No Start
DEEPAIR007
Okay i have a 97 honda accord, 5spd, 2.2L with 80K. My problem suggests a bad alternator, but i had it checked today at advanced auto and they said it was working properly. Symptoms of the problem include lack of power. For instance when i roll down my power windows at night i can see that my headlights and interior lights dim. This also occurs when i switch the air conditioning on. Upon idle my car feels like its about to die on me, especially when the air is on. Also, I noticed a few weeks ago that my engine was struggling to crank and it seemed that each day i started it the problem got worse until now it wont start at all. Please give me some suggesions.
Sep 12, 2007 at 5:32 PM
  • 75,988 POSTS
[quote:bcce0233f8="deepair007"]Okay i have a 97 honda accord, 5spd, 2.2L with 80K. My problem suggests a bad alternator, but i had it checked today at advanced auto and they said it was working properly. Symptoms of the problem include lack of power. For instance when i roll down my power windows at night i can see that my headlights and interior lights dim. This also occurs when i switch the air conditioning on. Upon idle my car feels like its about to die on me, especially when the air is on. Also, I noticed a few weeks ago that my engine was struggling to crank and it seemed that each day i started it the problem got worse until now it wont start at all. Please give me some suggesions.[/quote:bcce0233f8]
Get the battery capacity tested-if battery okay then check the alternator it might not be putting out-to do this read the voltage before you start the car-record it , now start the car -hit the lights if the reading is atleast 1.5 volts over the reading before you start the car -the alternator is doing its job.
Sep 12, 2007 at 11:41 PM
BRUCE HUNT
  • 3,754 POSTS
Ras is right on the alternator but I might add that places that test alternators don't seem to hit on the chance that the alternator can be doing its job of charging but may not know when to turn off. They over charge the battery and that is just as bad as not charging at all.
Sep 13, 2007 at 1:14 AM
Suggested Repair
Test the battery capacity first. If the battery is good, measure voltage before starting, then start the engine and turn on the lights; charging voltage should rise at least 1.5 volts. Also consider an alternator that overcharges and fails to shut off, which a parts-store test can miss.
Conversation Summary
The owner of a 1997 Honda Accord reports dimming headlights and interior lights when using power windows or air conditioning, a rough idle that feels like it may stall especially with the A/C on, and progressively worse cranking until the car will not start. An alternator test at a parts store reportedly passed. Experts recommend testing battery capacity, then verifying alternator output by comparing voltage before and after starting with the lights on, and considering an overcharging alternator that does not turn off.
