1996 Honda Accord Overheats With AC On
LOUMAY
HI there I have a 1996 hoday accord 2.0i es and it has done 124k miles. The problem is that when I put the air conditioning loses water from somewhere and causes the car to over heat and we don't know why, it does the same symptoms as if it was the radiator burst but only happens when the air con is on. Please if you can suggest any help as my hubby is good with cars.
Jun 26, 2007 at 4:41 AM
BRUCE HUNT
  • 3,754 POSTS
Read your post again and you will see that we don't have answers to that off the top of our head. We have no clue where the oil is coming from. Without that information no one can tell you what the damage to the vehicle and your pocket book will be.
Mar 26, 2007 at 7:59 AM
BRUCE HUNT
  • 3,754 POSTS
Her is my two cents worth. There is a leak in the cooling system for the car. The extra pull on the engine makes it increase the heat and it takes more to cool it. The heat expands something letting out coolant and letting air into the system. The air in the system decreases the boiling point of the system. It gets hot and the air in the system does not allow it to work as it was designed. Check for a leak at the radiator, even a small crack. If nothing is found has be gotten the engine good and warm with the radiator cap off to see if there is any bubbling? You could have the early stages of a head gasket failure.
Jun 26, 2007 at 7:28 AM
Suggested Repair
Inspect the cooling system for leaks, including a small radiator crack. With the engine fully warm and the radiator cap off, check for bubbling that could indicate early head gasket failure. The extra heat load from the air conditioning can expose a leak that lets coolant out and air in.
Conversation Summary
The owner of a 1996 Honda Accord reports coolant loss and overheating only when the air conditioning is on, with symptoms similar to a burst radiator. An expert suggests a cooling-system leak that appears under the added heat load, and recommends checking the radiator and looking for bubbles that may indicate early head gasket failure.
