I have a 98 accord with 245000 miles. When I start the car in idles fine for the first 5 minutes or so. Then when I hit the gas the car will idle between 3900 and 4000 rpm. Alternating back and forth between the two. If I tap the gas sometimes the car will back down to 3500 and maybe once it dropped to 2500. Also the temperature gauge doesn't move much but when I turn it off there is boiling coolant flowing back into the coolant resevoir.
Thanks
Thanks
Dec 7, 2006 at 8:14 AM
