2006 Honda Accord Left Turn Signal Fast
EDWINF
I have a 2006 honda accord, the left turn signal blinker flashes faster than the right. I took in for service and was told it was a loose bulb. But a day later it was doing the same thing. What could be other causes.
Mar 30, 2006 at 1:22 AM
LOSONE
  • 1,616 POSTS
Loose bulb, bad bulb, bad socket. There must be front and rear bulbs to have a proper flashing interval. With an 06, probably a bad bulb.
Mar 30, 2006 at 1:51 AM
Suggested Repair
Inspect and replace the left turn signal bulbs, including both front and rear, and check the sockets for looseness or poor contact. A bad bulb is the most likely cause of the faster flash rate.
Conversation Summary
The owner of a 2006 Honda Accord said the left turn signal flashes faster than the right. A shop blamed a loose bulb, but the problem returned the next day. The expert said a loose bulb, bad bulb, or bad socket can cause this, noted that both front and rear bulbs are needed for a proper flash interval, and said a bad bulb is most likely on this model.
