2003 Honda Accord Right Turn Signal Out
TONYSA
The right turnsignal on my 2003 accord stopped wroking completely. No lights come on either inside the car or outside. I am used to a burned out bulb where the light will come on and stay on. This time nothing comes on. Any Ideas?
Thanks
Mar 11, 2006 at 10:38 PM
2CARPRO JACK
  • 11,533 POSTS
could have too much in it. Try the A/C cycling switch, sometimes they cant handle the amps being pulled through them
Feb 14, 2006 at 9:33 AM
TANKBOY
thanks for your comment, unfortunately the fault was already there before it was recharged and i hoped the recharging would solve it.
Feb 15, 2006 at 5:50 AM
BRUCE HUNT
  • 3,754 POSTS
Start with the simplest such as the fuses. There are fuses located all over the place. On some of the newer accords there are fuses left and right covered with the exterior door on the dash and do not forget the fuses under the hood.
Mar 13, 2006 at 10:06 AM
Suggested Repair
Start by checking the fuses, including those behind the left and right dash end covers and the fuses under the hood.
Conversation Summary
The owner of a 2003 Honda Accord reported that the right turn signal stopped working completely, with no interior or exterior lights, unlike a typical burned-out bulb. One comment about an A/C cycling switch and a recharge did not match the turn-signal problem. An expert advised starting with the simplest check: inspect fuses in the dash and under the hood.
