2000 Honda Accord Left Turn Blinks Fast
ABC420
When I put on the left turn indicator, the arrow inside the car blinks very fast. The right turn arrow is normal.
I have shown it to my mechanic who replaced all left side bulbs but the problem continues.
What else can I do to fix this ? is taking the car to the dealer the only option ? how much could it cost ?
Sep 20, 2006 at 1:22 PM
BRUCE HUNT
  • 3,754 POSTS
I would try looking at the turn signal _____ (forgot what it is called) It should be located near the fuse box and it is responsible for breaking the power to the lights so they go on and off. Sorry about the bad memory but there could be one for each side. It is called a flasher. Check the flasher and replace if necessary. They get weak and can cause the flashing of turn signals to be faster or slower.
Sep 26, 2006 at 12:14 AM
Suggested Repair
Inspect the turn signal flasher near the fuse box and replace it if weak. There may be a separate flasher for each side.
Conversation Summary
The owner of a 2000 Honda Accord says the left turn indicator blinks very fast while the right side is normal. All left-side bulbs were already replaced without fixing the problem. The expert recommends checking and replacing the turn signal flasher near the fuse box, noting a weak flasher can make signals flash faster or slower and that each side may have its own unit.
