2004 Honda Accord Engine Air Filter
59,000 MILES • 6 CYL • 2WD • AUTOMATIC
MARILYN DUNN
For some reason, the screws holding the engine air filter will not come out to replace the filter. I have been told by two different oil change businesses that I will need to order the entire casing holding the air filter because they will have to break the screws to remove them. Being a SWF I have no idea if this is true or not. What should I do? My 04 Honda has 59K on it and I don't think the air filter has ever been replaced.
Feb 8, 2008 at 10:44 AM
MASTERTECHTIM
  • 4,750 POSTS
bring your car to a local repair shop, we have experience in removing these screws that the quick lube guys strip out. most likely your local garage will get the screws out. hope this helps
Feb 8, 2008 at 10:49 AM
