TCS light on?
2003 HONDA ACCORD
72,145 MILES • 6 CYL • FWD • AUTOMATIC
CARMAN123
brake light and TCS light coming on. dealer said brake fluid is sufficient but sensor is malfunctioning and reading brake fluid as empty thus causing brake and TCS light to come on. need to do brake fluid flush and sensor repair otherwise antilock brakes and traction control will not work?
Oct 3, 2009 at 3:49 AM
This is most always a speed sensor issue. Here is a guide on how to test them:
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
When you find which sensor the issue is, here is a guide on how to replace it:
https://www.2carpros.com/articles/how-to-replace-an-abs-wheel-speed-sensor
Also, you can check codes to find out which one it is and then test it as it states to make sure the sensor is the issue.
Let us know what you find and we can go from there. Thanks
Dec 8, 2020 at 6:23 AM
