2003 Honda Accord Check engine lights
7,000 MILES • 6 CYL • FWD • AUTOMATIC
ANDY BATTIS
What does P0141 02 Sensor Heater circuit malfunction Bank 1 Sensor 2 mean for the check engine light problem?
May 30, 2009 at 2:39 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:2f02436cf5="Andy Battis"]Engine Performance problem
2003 Honda Accord 6 cyl Front Wheel Drive Automatic 7000 miles
What does P0141 02 Sensor Heater circuit malfunction Bank 1 Sensor 2 mean for the check engine light problem?[/quote:2f02436cf5]
Hi Andy,
Most likely it is a bad O2 Sensor.
Bank 1 is the Passenger Side or if standing at front of engine it will be the left side.
Sensor 1 is in the Exhaust Manifold
Sensor 2 would be the next sensor back.
It could also be the wiring has melted from being in contact or to close to the exhaust. So crawl under the vehicle and check wiring.
If wiring looks good then replace sensor
Post results....
May 30, 2009 at 2:46 AM
