Check engine light
TAMMYULRICH
  • 2003 HONDA ACCORD
  • 6 CYL
  • 114,000 MILES
Good Afternoon;
I did a diagnostics on my car and the follow results came up and I need to know the best way to fix them, as follows:
P0116 Engine Coolant Temperature Circuit Range/Performance Problem
P1238 Fuel Pump Secondary Circuit Malfunction
P0506 Idle Control System RPM Lower Than Expected
P0155 Oxygen Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
P0121 Throttle/Pedal Position Sensor/Switch A Circuit Range/Performance Problem
What parts do I need and which is the most important one to fix.
Wednesday, November 11th, 2009 AT 5:12 PM
F4I_GUY
  • 3,302 POSTS
We cannot tell you exactly what parts to replace because you have to run a diagnostic on this items.
However it looks like you will need:
-ECT sensor
-TPS
-Oxygen sensor
Wednesday, November 11th, 2009 AT 6:06 PM
MONTERRIB
P0141 p1157 p0983
Monday, April 8th, 2019 AT 8:06 PM
MONTERRIB
Shaft solenoid d control circuit
Monday, April 8th, 2019 AT 8:13 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 47,643 POSTS
Excellent addition to this thread! Please feel free to help out whenever you are on the site :)
Tuesday, April 9th, 2019 AT 12:36 PM
