What brand plugs and wires did you install?
You should only use NGK plugs on that vehicle.
Also, retrieve the DTC, it may lead you to which cylinder is mis-firing and then you can try to see if it is a defective plug or wire.
SPONSORED LINKS
Thursday, April 9th, 2009 AT 6:13 PM
