Hi dmjacks1976,
DO NOT replace anything until you have confirmed the cause and items to be replaced. Honda injectors seldom fails and that is always the last on my list of possible causes.
When you mentioned the engine is running too hard, do you mean the engine is racing as if the trans is slipping?
Do you have difficulties starting after the engine has been stopped for a while?
You mentioned sputtering going up hills, have you checked the spark plugs? Symptoms indicates possible misfiring.
Is the Check Engine Indicating or sometimes indicates?
Get a free scan done at Autozone and let me know the EXACT trouble code if any found.
SPONSORED LINKS
Friday, July 16th, 2010 AT 9:24 AM
