Most sensors would emit an error code so if it is, you need a diagnostic on the data readings.
If it is fuel problem, it could be a clogged fuel filter, fuel pressure or fuel pump.
Jerking is usually due to sparking problem which can be due to the distributor coil, rotor, plugs or cables.
SPONSORED LINKS
Thursday, May 29th, 2008 AT 1:01 PM
