2001 Honda Accord engine stopped running has no spark
2001 HONDA ACCORD
BERT62
2001 Honda Accord Automatic
while engine was idling, engine shut off, was idling for about 1min. lifted hood found spark plug wire from cap to be disconnected, reconnected wire, tried to start engine, cranked over but no start, checked for spark, had none, removed cap, with volt meter checked coil and had 12v. with key on pos. what should I check for
Nov 1, 2010 at 6:17 AM
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Nov 1, 2010 at 6:47 PM
BERT62
THANKS FOR THE INFO ON THE 2001 HONDA ACCORD ......ENGINE SHUT OFF NO START AFTER SPARK PLUG WIRE WAS DISCONECTED OFF DIS...CAP ......CHECKED AND FOUND OUT DISTRIBUTOR WAS BAD REPLACED IT WITH A USED DISTRUBUTOR FROM A JUNK YARD FOR 100$....INSTALLED USED AND ENGINE FIRED RIGHT UP...THANKS
Nov 3, 2010 at 12:17 PM
