2000 Honda Accord Help
CHRISRACEING
  • 2000 HONDA ACCORD
  • 4 CYL
  • FWD
  • MANUAL
  • 130,000 MILES
Help my car is sputering I know it's a miss some were I have already changed the spark plugs, the egr vaule and checked the compression I've had some friends tell me that it's the fuel pump or the injecters so if you could please help and some advise oh it also has a few minor perfomance mods that I have installed.
Tuesday, January 6th, 2009 AT 3:09 AM
  • 31,937 POSTS
Hi there,
You will need to isolate the miss firing cylinder, do a compression check first and if that is ok, have the leads checked and also that each injector is working, if you feel that you can do this I will advise the procedure if not your mechanic can do this quickly for you, start here.
Mark (mhpautos)
Tuesday, January 6th, 2009 AT 3:13 AM
