2000 Honda Accord Cluster Lights Out
DAVIDROBERTSONJR
I own a 2000 Accord DX with 186 000km.Recently I decided to be a do it yourselfer and put in a new CD player however I hooked the wires up improperly the first time and now my Instrument cluster will not light up. All the little icons work as they should and the gauges and digital display are not effected. I checked all the fuses and even removed the cluster and replaced all the bulbs. I had a guy from a local Stereo shop check it out and he said he's never seen this before.
A new cluster is alot of money and id rather not but one to find out its something else.
What else could it be?
Oh yeah head lights work fine day time running lights havent worked since I bought the car and the SRS light stays on all the time.
Thankx in advance for any help!
Feb 23, 2007 at 11:35 AM
CHEVY22
  • 1,375 POSTS
if you replaced the bulbs and checked all of the fuses for the ip you may have a short to ground in the cluster especially if you powered the wrong wire
you can check these two things if you havent already fuse 6 and 9 left dash panel and passenger under dahs relay box fuse 13 applies to 2.3 and 3.0
Feb 23, 2007 at 12:00 PM
DAVIDROBERTSONJR
Thankx alot I didnt realize there was a box under the dash but what did you mean "relay box fuse 13 applies to 2.3 and 3.0?" Am I checking a fuse a relay?
I checked all the fuses in the left fuse box and the one on the right (of the dash)How do you check a relay?
Feb 23, 2007 at 12:41 PM
CHEVY22
  • 1,375 POSTS
im sorry i wasnt clear , they are called fuse / relay boxes and if you checked the fuses i stated the only other thing you could do is pull the cluster and check each wire for power , like the bulb sockets you could use a test light and see if they have power at the socket and trace the socket wire back to the cluster connector and i can help there if you need wire locations or colors hope this is a little more clear
if you are happy with the help consider leaving a vote and some feedback as a moderators we spend our spare time helping for free and its just like saying thank you
thanks
jim
Feb 23, 2007 at 12:50 PM
CHEVY22
  • 1,375 POSTS
btw depending on which engine you have the 4cyl printed circuit board for the cluster is 216.50 from the dealer 6cyl you have to buy the whole cluster which is 258.02
Feb 23, 2007 at 12:55 PM
Suggested Repair
Check left dash fuses 6 and 9 and passenger under-dash fuse/relay box fuse 13. If those are good, remove the cluster and use a test light to confirm power at the bulb sockets, then trace those wires back to the cluster connector. A short to ground from the miswired stereo is possible; cluster circuit-board or full cluster replacement is a last resort and depends on the engine.
Conversation Summary
The owner of a 2000 Honda Accord DX lost instrument-cluster illumination after incorrectly wiring a CD player. Icons, gauges, and the digital display still work, and the bulbs and known fuses were already checked. The expert recommended checking specific dash and under-dash fuses, then testing for power at the sockets and connector, and noted dealer prices for a cluster circuit board or complete cluster.
