1999 Honda Accord Type Oil To Use
SKYLAR_M
  • 1999 HONDA ACCORD
  • 4 CYL
  • 100,000 MILES
What oil is recommended to use for a 1999 Honda Accord with just a little over 100,000?
Friday, January 22nd, 2010 AT 2:06 PM
F4I_GUY
  • 3,302 POSTS
I would switch it up to a 10w30 high mileage conventional oil
Friday, January 22nd, 2010 AT 5:10 PM
SKYLAR_M
My original question:
Posted at Fri Jan 22, 2010 12:06 pm
By skylar_m, New to the forum
Engine Performance problem
1999 Honda Accord 4 cyl Two Wheel Drive
Automatic 100000 miles
Your Answer:
Posted at Fri Jan 22, 2010 3:10 pm
By F4I_guy, Moderator
The reason why I was asking this questions was because my wife took our 1999 Honda Accord to an oil change place called "Oil Can Henry's". "Oil Can Henry's" said that a synthetic oil was recommended by Honda as per their print sheet from Honda. I was unsure if that was the right type of oil to put in her car. It was the first time a synthetic oil had been used. It is my understanding that synthetic oil has a detergent so it will clean the engine while you are driving. Is this true? I have also heard that once you use a synthetic oil you cannot go back to using a conventional oil. Is this correct as well.
Sincerely,
Skylar_m
Friday, January 22nd, 2010 AT 8:54 PM
