1999 Honda Accord
ALYAFAI1
  • 1999 HONDA ACCORD
1999 Honda Accord 4 cyl Front Wheel Drive Automatic
i got a 99 honda acord when I start the car I get a flashing sign maintenance required
Thursday, November 26th, 2009 AT 4:28 PM
  • 31,937 POSTS
Hi there,
The maintenance light automatically starts flashing when you reach a certain mileage. It does not mean that you need to do maintenance (although scheduled maintenance is recommended), it is just a reminder.
Additionally, it is a reminder to change your oil. If you reset it each time you change you oil, then supposedly based on how you drive it the car will tell you to when to change the oil.
To reset your maintenance light, follow this procedure
Odometer reset button procedure
Turn the key to the II position (but not to III, or START)
Turn the key to the 0 (OFF) position, then push -- and hold -- the trip odometer reset button
Turn the key back to the II position, while still holding the button
After about 10-15 seconds, the light should go off
Release button and turn key to 0.
This should re set the warning,
Information sourced from various web pages.
Mark (mhpautos)
Thursday, November 26th, 2009 AT 4:35 PM
