1997 Honda Accord Steering is rough
VIBERT
Steering problem
1997 Honda Accord 4 cyl Front Wheel Drive Automatic 84,xxx miles
To whom it may concern:
I just had my rotors and brakes changed and couple days later i notice that the steering is rough and there is a noise coming from the left side wheel. I ask the mechanic and he said that the power steering pump is bad. What do you recommed me to do...Thank you for your cooperation.
Vibert Doobay
Dec 23, 2007 at 12:08 PM
  • 31,937 POSTS
Hi there,
Have the L/H/ Side steering and suspension and brakes inspected as something may have been left loose. The pump will not nesecarilly cause a noise in the wheel area, But if the pump was failing or low on fluid, you would feel a tugging sensation in the steering as the pressure in the hydraulics failed. You could also hear a whining noise from the pump.
Mark (mhpautos)
Dec 23, 2007 at 12:18 PM
