Hi i was searching the web for a good repair/advice site and i found this site to be very interesting and helpful. I hope you guys can help me. thanks.
I have a canadian 1997 honda accord lx/ex (i am not sure) 2.2 4cyl front 2 wheel drive with manual transmission. it has 214,000km on it. timing belt, 3 accessory belts, rear O2 sensor and water pump has just been changed last year (2006).
problems:
my engine light is off in some days but it is often on most of the time. i read in some forums that it could be the gas cap but i checked and every thing was fine.
my car makes a rattling noise in the exhaust near the cat converter. when i drive the noise goes away, but when i'm idling the noise comes back. also, my exhaust has this deep sound coming out at the same place where the rattling noise is coming. the deep sound is like if you have racing mufflers on.
could this be the cause of my engine light to turn on and off?
plus my passenger side high beam doesn't work. I have changed the bulbs but it still doesn't light up. my DRL warning lights are on but when i turn my headlights on it goes off. could this be an electrical problem and not a mere bulb replacement?
thanks...
problems:
thanks...
May 27, 2007 at 8:34 AM
