1997 Honda Accord CHECK ENGINE LIGHT ON
112,000 MILES • 4 CYL • 2WD • AUTOMATIC
HUNIEHUN
I have a 97 Honda Accord with a mileage of 112,000. For the past month, I had trouble with the catalytic converter and the distributor. I changed the catalytic sensor as well as the distributor. These 2 problems occurred simultaneously. Now, my check engine light is on and when I took in the shop, it shows Efficient low gas Sensor Bank #1 (something like that). So the mechanic just turned it off for me hoping that this was just because the sensor hasn't recognized the changes we made but I came back a week after because the light turned on again and its the same diagnostic from the computer. What can be wrong with this? Thanks!
Feb 4, 2008 at 11:57 AM
FISHERMAN
  • 937 POSTS
[quote:74aac0bef2="huniehun"]Electrical problem
1997 Honda Accord 4 cyl Two Wheel Drive Automatic 112000 miles
I have a 97 Honda Accord with a mileage of 112,000. For the past month, I had trouble with the catalytic converter and the distributor. I changed the catalytic sensor as well as the distributor. These 2 problems occurred simultaneously. Now, my check engine light is on and when I took in the shop, it shows Efficient low gas Sensor Bank #1 (something like that). So the mechanic just turned it off for me hoping that this was just because the sensor hasn't recognized the changes we made but I came back a week after because the light turned on again and its the same diagnostic from the computer. What can be wrong with this? Thanks![/quote:74aac0bef2]
Hello !!
which sensor was replaced?
The oxigen sensor?
or the Cat. converter?
also which code did you get?
let us know!
Feb 4, 2008 at 12:02 PM
