1995 Honda Accord
JIMMYLEE
  • 1995 HONDA ACCORD
  • 4 CYL
  • MANUAL
  • 148,000 MILES
How to change oil pan gasket?
Saturday, March 20th, 2010 AT 9:25 PM
HONDA TECH 1818
  • 536 POSTS
1. Drain the oil
2. Remove the lower center beam (5, 14mm bolts)
3. Remove the exhaust A-pipe by removing the 3 14 mm nuts and 2 14mm bolts and 12mm nuts.
4. Remove the torque converter cover (3, 10mm bolts) and remove the shift cable cover (3 12mm bolts).
5. Remove the 18 10mm bolts on the oil pan
6. Remove the oil pan and then the oil pan gasket.
7. Clean and apply Hondabond to front and rear of oil pan gasket.
7. Reinstall in reverse of removal.
Saturday, March 20th, 2010 AT 11:56 PM
