1994 Honda Accord CV Joint Boot Tear after 6 months
167,000 MILES • 4 CYL • FWD • MANUAL
BLECRONE
I had both drive axles replaced in June '07 after hearing knocking/clicking noise when making turns. This was done by, let's call them "Mechanic A". In December of '07, "Mechanic B", when performing a routine oil change, informed me that the CV joint boots were leaking grease and need to be replaced. I then had Mechanic B proceed to replace them. After beginning the work, they informed me that the inner boots both had tears in them and had leaked enough grease that the drive axles need to be replaced again. They showed me the torn boots and they were clean tears, almost like they had been cut. I can't imagine a rock or something from the road making nice clean cuts like that. Is it possible that the boots could have been inadvertantly damaged during installation when the drive axles were replaced the first time? Or that the boots they installed were defective?
Jan 10, 2008 at 8:06 AM
BRUCE HUNT
  • 3,754 POSTS
Or that a suspect mechanic put those in their to put a couple of bucks in his pocket?
Most re-manufacturers of the CV axles put a life-time warranty on them but they don't cover the boot being cut.
Jan 10, 2008 at 8:55 AM
