The soldering cracks are times very hard to spot (very fine hareline cracks) that causes this big mess. KHLow2008 is correct, once you re-solder correctly this should permenantly solve the problem.
About re-locating, that is because of accessibility. It is burred behind the cruse control box which requires you to remove all that. I read that you just need to mount in reverse to the main relay to sit beside the cruse control box verses underneath so next time (hope it does not) happen again, you just remove relay from casing without having to unbolt anything. During hot whether, there is no way for that relay not to get hot no matter where it is located (in my opinion) when windows are closed and been sitting in high heat for hours, but I also read and done was to create small holes on top of casing for ventilation. Just extra precaution for me.
SPONSORED LINKS
Wednesday, September 30th, 2020 AT 10:48 AM
