HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Honda
Accord
Engine
Oxygen Sensor
1991 Honda Accord OXYGEN SENSOR
BBORNITZ
MEMBER
1991 HONDA ACCORD
Engine Mechanical problem
1991 Honda Accord 4 cyl Front Wheel Drive 223457 miles
what will or can cause an oxygen sensor to keep going bad
Monday, May 26th, 2008 AT 7:40 PM
BMRFIXIT
MECHANIC
Check for a vacuum leaks
check if its running very rich
check fuel pressure
check for an exhaust leak
what is the codes
Monday, May 26th, 2008 AT 8:07 PM
KHLOW2008
MECHANIC
Contaminated fuel will also cause the problem
Tuesday, May 27th, 2008 AT 9:35 AM
Please
login
or
register
to post a reply.
Related Oxygen Sensor Content
Does Af Ratio Sensor Failure Mean Map Or O2 Sensor?
Check Engine Light Came On With Code P1164 (meaning: Af Ratio Sensor Performance Failure). Dealer Recommends A New A/f Ratio Sensor For My...
Asked by
hagengr
1 ANSWER
HONDA ACCORD
GUIDE
Oxygen Sensor
Oxygen sensors are made of reactive materials which limits their lifespan. Aside from mechanical failures such as shorted heating elements or physical damage, these sensors...
Oxygen Sensor Reset?
How Do I Reset The Oxygen Sensor Warning Light With A Manual Speedometer. According To The Manual This Light Comes On Every 90k Miles And...
Asked by
rsanderson33
1 ANSWER
1994
HONDA ACCORD
Oxygen Sensor ?
I Own A 1987 Honda Accord Dx With A 2.0. It Has 300,000 Miles On It. When I Start My Car The Idle Is A Little Sluggish, But After It Warms...
Asked by
carolcoleman
HONDA ACCORD
2003 Honda Accord 02 Censor
Af Censor Light Keeps Coming On
Asked by
bledsoe
2003
HONDA ACCORD
Code P0141 No Power To Heater Circuit?
Im Workin On A 2007 Honda Accord. Code P0141 No Power To Heater Circuit On Rear 02 Sensor. The Harness Runs Up Under The Pass. Side Seat....
Asked by
al514
1 ANSWER
1 IMAGE
2007
HONDA ACCORD
VIEW MORE
Oxygen Sensor Replacement Fix Code P0155
