Just had the timing belt replaced Apr. 12, 2008. After the repair, the car became very noisy. I can hear a loud humming noise even on idle mode. The repair shop said that it was the timing belt cover touching the belt inside and was causing the noise. They said I need to replace the cover because it was already bad. Is this true? Or am I being scammed for more money to get my car fixed and back to normal. I already spent over $400 dollars to get the timing belt replace. Is this just about right amount?
Thank you for your help.
Apr 20, 2008 at 5:05 AM
