timing marks for cam & crank shaft, oil pump, balance shft.fly wheel and #1 piston.#1. alignment.
189 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
ARAMHAROUTOUNIAN
While driving harmonic balance's bolt snapped off. The markings on all pulleys, flywheel, piston #1 are not aligning right? Can I get the timing marks please?
Feb 23, 2015 at 9:20 PM
HMAC300
  • 48,601 POSTS
Yep the timing marks must be on for the engine to run right here is both 4 and 6 cylinder engine so it will help everyone that come to this page.
https://www.2carpros.com/diagrams/honda/accord/1990
Cheers
Jan 11, 2021 at 3:12 AM
