crankshaft timing belt gear removal
170,000 MILES • 2.2L • 4 CYL • FWD • AUTOMATIC
RICK DAVIS
How can I remove the gear on the crankshaft timing belt pulley with the woodruff key that stops me from removing my oil pump housing? Is there a puller made for this, if so where would I be able to locate one? Or is there a different way of having it release itself from that woodruff key that the harmonic balancer goes over?
Sep 20, 2016 at 1:03 PM
  • 31,937 POSTS
If the gear has two tapped holes in it you will be able to use a puller that attaches to these holes, most parts stores have these pullers in various sizes.
Sep 20, 2016 at 10:31 PM
RICK DAVIS
It's called the balancer driven gear which has no threaded holes on the side of it to thread any bolts for a puller to use. l also noticed it has one little area for a claw arm to slide behind the gear but no other area for a second claw arm to slide behind the gear which baffles me on how to remove it?
Sep 21, 2016 at 3:09 PM
  • 55,797 POSTS
Hey Rick, can you please upload a picture so we can see what you are talking about, this will help us help you
Best, Ken
Sep 25, 2016 at 1:02 PM
