1990 Honda Accord speedometer
JBS4448
  • 1990 HONDA ACCORD
  • 4 CYL
  • FWD
  • MANUAL
  • 359,000 MILES
Speedometer erratic. Comes and goes. Mostly
works on highway but not in town. But will work at
lower speeds sometime.I am in a quandry as to
what to change out? Please advise.
Tuesday, May 11th, 2010 AT 4:21 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
If your speedometer is reading inaccurate most of the time, check for an improperly installed speed sensor, defective instrument panel printed circuit or bad wiring to the instrument panel.
Tuesday, May 11th, 2010 AT 4:43 PM
JBS4448
Read my origional question again. When my speedometer works it seems to be accurate. However it is irratic as to when it works. And I don't know what to change out? The speed
sensor or the shaft the the speed sensor attaches to
that goes in the transmission?
Tuesday, May 11th, 2010 AT 5:14 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Yes, I read it correctly the first time. I simply used the wrong word, I meant erratic, my apologies.
The speed sensor is mounted on top of the transaxle, just below the thermostat housing. If the shaft was at fault then the speedo would be inoperative all the time. Also check out the ground wiring at the speed sensor, a loose or damaged ground could cause intermittent issues as well.
Tuesday, May 11th, 2010 AT 5:21 PM
JBS4448
Thanks I'll give it a try. Jody
Tuesday, May 11th, 2010 AT 5:27 PM
2 LINSEY
  • 287 POSTS
Thank you for using 2CarPros. Com. We appreciate your donation and look forward to helping you in the future.
Monday, May 17th, 2010 AT 12:48 PM
