1990 Honda Accord
MPEARSON20
  • 1990 HONDA ACCORD
  • 4 CYL
  • FWD
  • 150,000 MILES
My speedometer started working fine then it increased faster than it should, then the needle pointed straight down and now it wont move at all.
Tuesday, July 13th, 2010 AT 4:01 PM
KHLOW2008
  • 41,814 POSTS
Hi mpearson20,
Seems the Vehicle Speed Sensor is faulty causing the erratic speedometer operations. If the needle has overshot and is pointing to the bottom, you need to turn the needle backwards towards zero to make it work again.
As to the erraric running, most probably a VSS change would fix the problem.
Thursday, July 15th, 2010 AT 4:08 PM
