Transmission problem
1990 Honda Accord 4 cyl Front Wheel Drive Manual 188.00 miles
Have tried vacuum pump (Mityvac)....have reversed flow of fluid and pumped from the slave cylinder towards the master cylinder....nothing seems to work or make it better......I've even installed a speed bleeder at the slave cylinder.....you can see that the master cylinder is pumping the fluid as it flows through the clear tubing....
And there appears to be no leaks as there are no puddles to speak of and the level in the resorvoir is not changing...
the entire clutch system has been replaced with a clutch kit..a new master and slave cylinder. the pedal stays on the floor....only one time did I get just a tiny amount of pressure but I lost it.....
Aug 6, 2010 at 11:34 AM
