1990 Honda Accord clutch
1990 HONDA ACCORD
MARKMDDLBRY
Transmission problem
1990 Honda Accord Front Wheel Drive Manual
i'm having trouble with my clutch i have replaced the master cylinder the slave cylinder and bleed the line but the clutch still falls to the floor when i bleed the line there is not any pressure the fluid just runs out it doesn't squirt out
Nov 6, 2008 at 12:36 AM
KHLOW2008
  • 41,814 POSTS
Hi markmddlbry,
When bleeding the system, you need to manually lift the clutch pedal as there is a assist spring that would push the pedal to the floor when there is no pressure.
Check if the pedal to master cylinder push rod clearance is properly adjusted.
Nov 16, 2008 at 1:42 AM
