1996 Honda Accord clutch fluid/clutch pressure
1996 HONDA ACCORD
JAMESFOX125
1996 Honda Accord 4 cyl Front Wheel Drive Manual 209xxx miles
one day my clutch lost its pressure. would not engage. so i cant put it in gear.
i filled it with fluid. nothing happened.
if i bleed the the fluid will that help?
and where do i bleed it from?
Mar 26, 2010 at 5:56 AM
KHLOW2008
  • 41,814 POSTS
Hi jamesfox125,
If the master or slave cylinder has not failed too badly, bleeding the system can work, but would only be temporary.
Bleeding is done at the slave cylinder where you would find a bleeder nut.
Mar 30, 2010 at 3:20 AM
