1989 Honda Accord car wont start
BADBOY2150
  • 1989 HONDA ACCORD
Engine Mechanical problem
1989 Honda Accord 4 cyl Front Wheel Drive Automatic
the distributor went out on my 89 honda accord lxi and I bought a new one and installed it and got a new cap, rotor, and spark plug wires and also a new battery I cant the car to start. What should I do?
Friday, April 10th, 2009 AT 6:11 PM
Do you have fuel pressure and ignition spark?
Wednesday, September 30th, 2020 AT 11:09 AM
BADBOY2150
  • 13 POSTS
Yes I do have fuel pressure and spark. At first we thought it was a fuel pump but it works fine
What is the fuel pressure reading? Also do you have injection pulses
BADBOY2150
  • 13 POSTS
I dont know how to test fuel pressure and I dont know what injection pulses are?
BADBOY2150
  • 13 POSTS
The battery I bought back in february and I think it may be shot we tried to charge it today and it wont hold a charge.
Did you mark the distributor and rotor before you installed the new one -if not your valve and ignition timing is off-
BADBOY2150
  • 13 POSTS
Yes I did, on my certain type of vehicle the timing is controlled by the program fuel injection computer
Get somebody that knows how to check fuel pressure and injection pulses then comeback with some results I need this information before I can conitnue.
BADBOY2150
  • 13 POSTS
Ok
HAWAII-5-O
Hey badboy2150. I'm having the same problem. Did you ever figure it out? I changed everything possible already. I have spark and fuel pressure changed the main relay, distributor, coil, batttery, alternator, plugs and wires etc. Even my mechanic can't figure it out. Please let me know if you help. Thanks
KEN L
  • MASTER CERTIFIED MECHANIC
  • 54,336 POSTS
Does the engine have compression? I am thinking the timing belt has jumped a couple teeth.
Here is a guide to check it.
Best, Ken
