1987 Honda Accord Smoke
99,000 MILES • 4 CYL • 2WD • AUTOMATIC
GARRETT7
White smoke coming through A/C vents. Car still runs normal. Smoke also comes from underneath hood normally when slowing to 0-5 mph after driving above 40. Has a burning or exhaust like smell. However I also have an exhaust leek so that could be what I'm smelling. It does not matter if the heater or A/C is on. I can normally avoid any smoke coming out from the hood or vents if I accelerate very slowly. However, if I accelerate very fast It can become so smokey in the cab that I have to roll down the windows. Does not affect the performance of the car what so ever though. Any ideas?
Apr 16, 2010 at 9:04 AM
CARADIODOC
  • 34,400 POSTS
Hi garrett7. Welcome to the forum. Suspect a leaking heater core. You should also see a puddle on the ground between the two front tires. That is antifreeze dripping from the drain pan for condensation from the air conditioning system. You should also see the level going down in the radiator or overflow reservoir.
caradiodoc
Apr 16, 2010 at 10:42 AM
CARADIODOC
  • 34,400 POSTS
Hmmm. Per your other post, I can think of a few other things but the vehicle speed thing adds some confusion. I should have added that a leaking heater core would leave an oily residue on the windshield and dash.
Can you stop and pop the hood open when this happens? For the smoke to be that bad, it would seem it is more than just an oil leak. I would start by looking for oil running along the back of the engine and dripping onto the exhaust manifold. There will be a black crusty residue if oil is dripping onto exhaust parts after they cool down. It sounds like the oil is puddling somewhere, then running off under the right conditions.
A totally different thing to look for is the generator / power steering belt. If there is no smoke when the engine is idling, have a helper hold the brake pedal and accelerate a little in gear. That will rock the engine. Try that in reverse too. If the smoke suddenly appears, suspect a worn rubber isolator in an engine mount. That will allow the engine to sit low and a pulley can contact a plastic shield.
Another possibility is a shorted radiator fan motor. I had a car at the local racetrack many years ago that had an electric fan. While minding my own business idling in the pits, all of a sudden I couldn't see through the windshield. A friend came over and offered his fire extinguisher thinking I was on fire. Turns out the smoke was coming from the fan motor. There was no smell typical of burning wiring so at first I just thought it was getting foggy outside. Your fan will rarely run on the highway, but once the engine is warm, it will turn on when you slow down or stop moving.
Since you think there's an exhaust leak, there might be hot exhaust gas blowing onto plastic parts. The amount of smoke you described seems kind of extreme to be caused by this, but it's not something to overlook.
caradiodoc
Apr 16, 2010 at 4:06 PM
