1997 Holden Commodore car wont start
ANDREWS88
Engine Mechanical problem
1997 Holden Commodore 6 cyl Two Wheel Drive Manual
I had the car runing the day before and i had to jump start it so after i took the battery out to put on charge ive put it back in today and it just turns over and dont fire what should i check?
Jun 19, 2009 at 7:47 PM
  • 31,937 POSTS
Hi there,
See if the fuel pump is running for a few sec when you turn on the key, check for spark & injector pulse do this first.
Mark (mhpautos)
Jun 20, 2009 at 11:04 PM
ANDREWS88
well lve check for spark its ok and injectors are making a pulse im not sure if the fuel pump is working is it near the tank? also where would i find the fuel filter? could the fuel pump relay be stuffed and if so where would i find it thank you
Jun 21, 2009 at 1:29 AM
  • 31,937 POSTS
Hi there,
The fuel pump is internal, the filter is at the back near the axle R/H/S, the relay is under the black cover r/H/F engine bay, you should hear the pump humm for a few sec with key on.
Mark (mhpautos)
Jun 22, 2009 at 5:17 PM
ANDREWS88
the fuel pump is stuffed mate thanks for the help
Jun 25, 2009 at 8:18 PM
