Hesitation on acceleration
240,000 MILES • 3.1L • 6 CYL • 2WD • AUTOMATIC
GLDOUTT
The engine starts fine, and runs perfectly for the first two stops. On the third stop and sometime the fourth, there is a hesitation when trying to accelerate from the stop. After that, it runs perfectly. A couple of times, the engine shut off, but started up again.
Six months ago, in winter, the engine would shut off, and it took several minutes before I could get it started again, then it ran perfectly with no hesitation.
The shop found low fuel pressure, replaced what I think was the ignition module, and the computer. It worked fine for a while, then the hesitation has started again.
Coincidentally, the heater stops working when the engine has the hesitation problem.
My mechanic and I are having fits trying to figure this out.
Jun 4, 2019 at 5:09 AM
Good afternoon,
If the fuel pressure was low, why did he replace the ignition module? The fuel pump is the reason for low fuel pressure.
https://www.2carpros.com/articles/engine-hesitates
What was or is the fuel pressure?
Jun 4, 2019 at 5:28 AM
