this just started yesterday. when it shifts out of 1st, there is a 2 second hesitation. no acceleration at this time. once it shifts, it doesnt do it again for 3rd/4rth.
I did find a snapped vacuum connector mounted in the firewall right in front of the steering wheel. i fixed this best i could, the hesitation isnt as bad but is still present.
does the transmission have a vacuum line? if so, why would it only affect 1st gear? it still has plenty of power, its just the 2 second delay when going into 2nd it looses a lil bit of power. any ideas guys???
btw, the vac line is directly behind the brake booster vacuum hose "a fairly big hose" which makes it hard to get to. but is still doable...
Nov 18, 2008 at 5:29 PM
