1997 Chevy Lumina hesitation
1997 CHEVROLET LUMINA
100,800 MILES • 6 CYL • FWD • AUTOMATIC
MIKE55060
I recently changed plugs and ires from standard plugs to champion double plat power plugs gapped to vehicle .060 now when driving up hills there is a hesitation why????
Feb 23, 2010 at 10:14 AM
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Feb 23, 2010 at 10:17 AM
