Car shuts off when fuel tank down to half a tank
RICK JOHNS
  • 16 POSTS
New pump, same issue.
Wednesday, June 26th, 2019 AT 5:26 AM
  • 52,797 POSTS
Did you verify power to the pump when you had it apart? The power comes down th line from the inertia switch to the switching valve to the pump.
Wednesday, June 26th, 2019 AT 6:41 AM
RICK JOHNS
  • 16 POSTS
Yes.
Wednesday, June 26th, 2019 AT 7:12 AM
  • 52,797 POSTS
New or used pump. Was there power?
Wednesday, June 26th, 2019 AT 7:43 AM
RICK JOHNS
  • 16 POSTS
New, and yes.
Wednesday, June 26th, 2019 AT 8:30 AM
  • 52,797 POSTS
Did you verify the issue with a gauge when it happened?
When you replaced the pump, did you look inside the tank at the baffles? A broken baffle in the tank will allow fuel slosh and that would cause it to lose pressure.
Wednesday, June 26th, 2019 AT 1:08 PM
